It is currently Fri Aug 01, 2025 9:13 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
PostPosted: Sat Aug 16, 2008 11:33 am
First name: Heath
Last Name: Blair
City: Visalia
im not sure if anyone has mentioned this yet, but i made my go bar deck to be adjustable in height. i know others have done the same. all of my go bars are 24" in length. i simply adjust the height of the deck for the appropriate operation. the height is adjustable via 4 pieces of all-thread, nuts and washers. hope the picture explains it well enough.
sweat the small stuff.
PostPosted: Sat Aug 16, 2008 12:15 pm
Perhaps someone else has already thought of this, but it would be really cool to have quick-release nuts for this, like those found on some drill press depth adjustments, where you push a button in the middle of the nut, and can then slide it up and down. It'd also be cool just to say that you have quick-release nuts.
PostPosted: Sat Aug 16, 2008 12:53 pm
First name: Heath
Last Name: Blair
City: Visalia
laughing6-hehe laughing6-hehe laughing6-hehe
PostPosted: Sat Aug 16, 2008 1:07 pm
This version doesn't use such "quick-release nuts" (!), but it is a way to adjust the deck easily. I used two pipe-clamp parts for each corner and have notched out the corners. It works for me!
Kathy
Kathy Matsushita
San Jose, CA USA
http://theamateurluthier.com
Facebook: https://www.facebook.com/kathy.matsushita
PostPosted: Sat Aug 16, 2008 1:08 pm
Brilliant, Kathy! I love it.
Todd, I haven't had luck finding the motorized deck, but sure sounds cool.
PostPosted: Sat Aug 16, 2008 1:26 pm
I didn't actually come up with this idea myself — it came from an Internet friend, Mark Frazier — he did it somewhat differently, using only one pipe-clamp part underneath an adjustable bottom deck, which would work well, also.
Couple this with Hesh's great pull-out TV swivel idea (which I used this summer), and you have a very, very easy to use go-bar deck!!! (I did a little video on this because I was so tickled with how it came out: http://home.comcast.net/~kathymatsushita/moreprojects/htmlpages/atc12.html)
(The video is at the bottom of the page.)
Kathy
Kathy Matsushita
San Jose, CA USA
PostPosted: Sat Aug 16, 2008 2:10 pm
I've posted this before, but checkout how George Lowden does it. It's a bicycle innertube with fabric straps stapled to plywood.
PostPosted: Sat Aug 16, 2008 3:10 pm
Here's me gluing the back with go bars, well, sort of.
Also, the support bars have fixed inner blocks, so if I wanted to adjust the height, I could add a slotted spacer by loosening the wing nut and slipping it in on each rod. What I do, however, is have a fixed height and add a spacer to the go-bars when I'm gluing at deck level. You can see the spacers in the top of the bars in this picture.
level.
PostPosted: Wed Aug 27, 2008 11:17 pm
Anybody use go bar deck to glue on the bridge?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Wed Aug 27, 2008 11:20 pm
Kathy where do you get those fittings where the pipe goes into the plywood on the base and on top?
Rich Smith
Issaquah, WA
PostPosted: Thu Aug 28, 2008 8:33 am
I just get those pipe clamps and only use the little end part (not the handle part) — find the cheaper pipe clamps and it won't be as expensive. You need 2 per corner, so 8 total. You just notch the corner of the deck to accommodate the clamp part.
Kathy
Kathy Matsushita
San Jose, CA USA
PostPosted: Thu Aug 28, 2008 9:38 am
Kathy
Nice video Kathy! [:Y:]
PostPosted: Thu Aug 28, 2008 12:25 pm
Very nice video, Kathy.
PostPosted: Thu Aug 28, 2008 12:50 pm
Heath, I did the same thing many moons ago but I use 3/4" althread so I could make the deck 40" tall and very rigid. One of the best fixture re-works I have done. it is not as quick as pipe clamps to change heights but it only takes a min. or so. I also doubled up the 3/4" birch play decks to 2 sheets (1.5 total) to eliminate as much deflection as possible. I mounted a large heavy duty lazy susan on the bottom and attached to a dedicated 36x36 bench. I have (4) 3/8" dia holes drilled thru the lower deck 90 degrees apart and one in the bench top and use a 3/8 dowel as a locking pin while riging bars. I reall love this setup .
PostPosted: Thu Aug 28, 2008 4:56 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
I do the same as Heath.This works really well for me to be able to adjust the height.It seems a lot more versatile this way.
James W B
James W Bolan
Nashville Tennessee
PostPosted: Thu Aug 28, 2008 5:00 pm
Is it just me or does it look like there is a guy's head being squeezed out of this press......
PostPosted: Thu Aug 28, 2008 5:36 pm
Anybody ever consider just having two different length fiberglass go bars on hand? Works for me.
PostPosted: Sun Oct 19, 2008 12:47 am
http://www.tvshelves.com/images/225_2.gif
Is this the swivel used on the go bar deck ??
thanks Ange
PostPosted: Sun Oct 19, 2008 7:57 am
I don't use two different sizes of go bar rods, but do have two different sizes of 1/2" threaded rod for the go bar deck. Since I keep the deck broken down when not in use, I just pick the shorter set when setting up to glue braces to the plates, or the longer set when gluing the top and back plates to the sides.
Users browsing this forum: J De Rocher and 19 guests
